Changing The Subject Name?
   / Changing The Subject Name? #1
Harv
Elite Member
California - S.F. East Bay & Sierra foothills
Kubota L2500DT Standard Transmission
Gotta question that's been tickling around in the back of my mind for a while now --
Maybe it's just 'cuz I always use the Past 24 Hours mode, but I find it somewhat confusing when the subject line has been altered. Okay, it doesn't take that much to confuse me, I admit, but I was wondering what the intended purpose is for allowing that field to change. It seems like it's really the title of the thread and might be better left alone, for readibility sake.
If I'm the only one who has even thought about this, then let's pretend I never said anything. /w3tcompact/icons/crazy.gif
   / Changing The Subject Name? #2
Re: What me change the subject?
Harv,
I'll pretend you never said anything. /w3tcompact/icons/smile.gif Seriously, I've thought about it, but since I always read in flat mode, I take the subject line change as a clue that this is one of those "wandering threads". I like it. /w3tcompact/icons/smile.gif
The GlueGuy
<font color=blue>I always read in flat mode</font color=blue>
I use flat mode as much as possible myself. But how do you find the thread in the first place? By subject?
This is not a really big deal to me. Just curious about what other folks think.
   / Changing The Subject Name? #4
I like to change on the fly...
It allows some amplification and/or clarification of a particular subject... /w3tcompact/icons/smile.gif
   / Changing The Subject Name? #5
I find it easier to use "Forum Home" as my opening page rather than "past 24 hours" This keeps the threads in their original category with original subject lines. New posts are flagged. It may be harder on slow Internet connections since you end up downloading the entire page to get to the new post at the bottom.
   / Changing The Subject Name? #6
Harv,
I too find it a little confusing when the subject line is changed. I tend to look for subject lines that I have already read and then skip around the others. Back when this board was smaller I would try to read all the posts...
DaveV
   / Changing The Subject Name? #7
Re: Changing The Subject Name?/Why I do it
I've been guilty of changing the subject line on several occasions. Mostly due to significant topic drift (which I am also guilty of) in a situation where the new topic doesn't warrant it's own place in the forum. I typically read in the past XX hour mode and it's easy to see the drifted subject like that. On the other hand, it's frustrating to me to open a post and have the contents completely different. Recent example being the hinged boxblade thread. I opened one post and it was talking about magnets! What could that possibly have to do with boxblades? Oh yeah, that was my addition /w3tcompact/icons/smile.gif
I think I picked this habit up from and RV forum that did not have a flat mode. It also had a lot of drift but since people typically renamed the subject upon drift it made it easy to determine if you wanted to go there.
See, there I go drifting again /w3tcompact/icons/smile.gif
   / Changing The Subject Name? #8
Harv,
Seems like subject line changes are used to emphasize individual posts more than to track the discussion. A lot of threads wander but somehow return to the basic subject. I haven't seen the need for a traffic cop to direct my reading.
Al
   / Changing The Subject Name? #9
Re: I always read in flat mode
I generally peruse the forums from the top level, and dip into the ones that "start" (yes, the initial subject) with something that I'm interested in. I have my default mode set to flat, and I go from there. Since I read them flat, I see the transitions, and use the subject changes as clues to the drift.
Also, because Muhamad tracks what I've read (and haven't), checking in every couple days works to keep me posted on what's happening.
The GlueGuy
   / Changing The Subject Name? #10
Rob,
Sometimes I want to follow a topic and know what the thread name was. I go back to check it later and miss different posts because the topic was changed. Yes, the topic name many times has nothing to do with what is being discussed. Guess this is only an issue for people like me who like to use flat mode and don't have time to read everything...
DaveV
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2020 DRAGON ESP...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2023 Ford F-150 Crew Cab Pickup Truck (A59230)
2023 Ford F-150...
