Oil & Fuel Changing the fuel filter on a MF1643
   / Changing the fuel filter on a MF1643 #1
jtheise4
SE Michigan
Massey Ferguson 1643 & Allis-Chalmers D14
Has anyone changed their fuel filter on a MF1643 (or any 1600 series tractor)? Mine is going to need changed fairly soon and the owners manual really isn't very descriptive. I've never owned a diesel before and it's my understanding that the fuel system needs to be bled after changing the fuel filter. I'm not sure how to do that. Any input would be greatly appreciated. Thanks.
   / Changing the fuel filter on a MF1643 #2
Turn off the fuel, unscrew the big nut holding the plastic bowl on, remove & replace filter element, install the plastic bowl making sure the o-ring is in place. I leave the bowl a bit loose & turn the fuel back on to let the bowl fill with fuel & push the air out, then tighten the big nut. Tight hand tight. Turn the key & leave it to the run position to let the fuel pump run a few seconds, the it should fire right up.
Thanks!
   / Changing the fuel filter on a MF1643 #4
That is exactly how we do it, and it works great. We change the filter every fall, and strain all fuel when we fill the tractor.
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2013 Ver-Mac Solar S/A Towable Trailer Message Board (A49461)
2013 Ver-Mac Solar...
2011 ORTEQ ENERGY SERVICES 40 MANIFOLD TRAILER (A50854)
2011 ORTEQ ENERGY...
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
