changing seals in a hydraulic cylinder
   / changing seals in a hydraulic cylinder #1
jinmared
Bronze Member
Goldendale,Wa
Jinma 354 fwd
I need to change a bad seal in my dump valve cylinder on my jinma FEL JM ZL-30.Can anyone give me advice on how to do this?
A cylinder schematic would be nice also
I ran a check on both cylinders and only the top hose on the right side leaked fluid by.
   / changing seals in a hydraulic cylinder #2
If you are just changing seals on the lines that's quite easy. If you are changing seals within the cylinder it's still pretty easy. I took mine apart for the first time abput a month ago. You can use the stands to prop the FEL. I only took the upper end of the cylinder. Disconnect the lines. It will slide off. Make sure to keep it all clean. dirt will tear up the inside of the cylinder and system. Put it back together and bleed the air out. Question do you have seals already hoses or cylinder and where did you get them I'm still waiting on mine.
Newt
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
UNUSED AGT SDA 140W WHEEL LOADER (A51247)
UNUSED AGT SDA...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
(APPROX 36) 2" X 5" X 21" CHANNEL IRON (A51247)
(APPROX 36) 2" X...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2022 LOAD TRAIL 8' X 24' TRAILER (A51247)
2022 LOAD TRAIL 8'...
