Oil & Fuel Changing out PTO oil seal Ford 3910
   / Changing out PTO oil seal Ford 3910 #1
jaygee
I have Ford 3910 1986 and the PTO shaft is seaping and I would like to replace the seal.Is that a big job?
   / Changing out PTO oil seal Ford 3910 #2
not sure on a 3910 but 4630 just drive the tractor down into a small ditch. So the tail end will be up higher then should be 4 bolt holding a fange containing the seal. also there might be a pto safty shield to take off. Just DONT pull the pto shaft out. Should take 30 minutes. remenber do not take the pto shaft out. the seal is connected to the frange.then rebolt everything and recheck hyd level. good luck
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
2013 John Deere 310SK (A47384)
2013 John Deere...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
Unused 2025 CFG MY50R Mini Excavator (A49461)
Unused 2025 CFG...
VENTRAC 4500Z ARTICULATING TRACTOR (A51242)
VENTRAC 4500Z...
