Rotary Cutter Changing oil
   / Changing oil #1
Buddycat68
Grayson ky
Massey ferguson 253,kubota M6040,New Holland TC40DA,Farmall Super A
I want to change the oil in my brush hog I think it's an international brand but not sure but I do know it's not a ihc brand. It has a large plug at the top and another small one a little over half way down. My question is what plug to I fill to. Also is 85w-140 gear oil good to use?
   / Changing oil #2
I just bought a Brush Hog Razor Back and the plugs on the gear box are similar to what you describe on your unit.
When the dealer dropped it off I asked him about filling the gearbox and he told me that when they fill them they put the brushhog on a level surface, remove the plug halfway down the gearbox casing, remove the top plug and fill with gear oil from the top plug until the gear oil reaches the bottom level of the lower hole in the gearbox and then replace both plugs. I didn't ask him what type of gear oil they used.
You want to google an owners manual for a unit similar to yours and that will probably give you the information on the type of gear oil to buy.
   / Changing oil
Ok thanks I know mine isn't a brush hog because it doesn't have the same gear box on it and I have seen some in the past that said international and they looked identical to mine. Also what would be a good way to get all the oil out and flush the box out?
   / Changing oil #4
i took the easier route and pulled the top of the gear box off (4 bolts) for easier access...
On my JD brand i used amsoil severe-gear 75w90
on mine the plug in the middle is the full line...
brian
   / Changing oil
It has set out all of its life and it had a few small pieces of metal in it when I changed it along with a little bit of water.
   / Changing oil #7
As Plas said, you fill from the top. When the oil starts coming out the plug hole on the side of the gearbox, it's full.
I've used these to pump oil out of a gearbox. Multi-Use Transfer Pump
They are cheap enough to use them and then throw them away when you're done. Or, you can spend more money and buy a real oil extractor that will work better and last longer. E.g., something like this: Pneumatic Oil Extractor
3-point Boom Sprayer 72ft (A52128)
3-point Boom...
2009 Lexus RX350 (A50324)
2009 Lexus RX350...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
2023 JOHN DEERE 317G SKID STEER (A51242)
2023 JOHN DEERE...
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
2014 Caterpillar 257D Compact Track Loader Skid Steer (A50322)
2014 Caterpillar...
