Changing Hydro Fluid Question
   / Changing Hydro Fluid Question #1
scsims
Central, KY
Mahindra 5525
I'm going to be changing my UTF this week for the first time. I'm going to completly change the fluid install new filter and clean the screen.
After I refill the fluid and install the filter, is there any type of priming or bleeding of the hydraulic system that needs to be done before using the FEL, 3 pt and rear remotes?
Thanks,
Scott
   / Changing Hydro Fluid Question #2
most hyds will auto bleed with use.. cycling cyls to max and back helps.
in some applictions some pump have bleeders on them you can open if needed.
soundguy
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A54607)
2007 FREIGHTLINER...
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
Light Tower (A52377)
