Changing Hydraulic oil
   / Changing Hydraulic oil #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I am needing to do the 50hr hydraulic fluid change and have been debating what fluid to put in. The manufacturer spec is Citgo Hydraulic Tractor Fluid. That is all it says in the manual. From that I assume any brand of standard Tractor fluid should be OK. I have been debating on switching it to a UTF. So my question is what about the fluid in the lines to the FEL? Do I need to worry about the fluid in the lines when I change the oil? How would I go about emptying the lines if I need to? Does it make a difference about the oil in the lines if I use a standard tractor fluid or UTF?
   / Changing Hydraulic oil #2
Nope, no need to worry about the oil in the lines.
   / Changing Hydraulic oil #3
For all intents and purposes.. 'standard tractor fluid'.. pretty much is UTF... they are all refering to a multi use fluid.
Aboutt he only differences you see are for some that are made for wet brakes / clutches.. and some may be synthetic.. or have other special formulations like kubota's 'super utd'.. etc..
Soundguy
   / Changing Hydraulic oil #4
Are you sure that the hydraulic fluid must all be changed at 50 hours? With my new tractor (NH) all that the book called for was a filter change.
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
2017 Ford F-650 Stakebody Flatbed Truck (A53422)
2017 Ford F-650...
2017 TRAILSTART 40FT DUMP TRAILER (A54607)
2017 TRAILSTART...
2024 TIMPTE HOPPER 43FT HOPPER TRAILER (A54607)
2024 TIMPTE HOPPER...
Utility Trailer (A52377)
Utility Trailer...
2018 FORD F150 XL TRUCK (A51406)
2018 FORD F150 XL...
