Changing Hydraulic Fluid on my 4035HST
   / Changing Hydraulic Fluid on my 4035HST #1
lantxinNETX
Bronze Member
NE Texas
Kubota BX23S
Next weekend I am planning on doing the 50 hour service on my Mahindra 4035HST. I plan on buying my new hydraulic fluid in 5 gallon buckets, but I am left with how to get the new fluid into the tractor. Since I don't expect to be doing this more than once a year, I don't want to spend a lot of money on a solution. I was thinking of a hand pump to transfer from the 5 gal bucket direct to the tractor, but they seem to be rated at about 3 ounces a stroke. Ten gallons will take some time - and some elbow grease!
Thanks!
Martin
   / Changing Hydraulic Fluid on my 4035HST #2
Thanks!
r.
Martin
I've always simply put a funnel in the fill hole and pour it in from the 5 gallon bucket but my fill hole is right at your feet when on the tractor. If this is too cumbersome depending on where your fill hole is, get a smaller container such as the bottle 20 lbs of kitty litter comes in and pour it in with that after the transfer. My dealer seems not to have the Mahindra fluid in 2 and a half gal. container. A bit more expensive to get it this way but a lot easier to manipulate.
2012 Ram 3500 Crew Cab Flat Bed Truck (A53422)
2012 Ram 3500 Crew...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A52377)
2021 Fleco DX140...
2016 KENWORTH W900 T/A DAY CAB ROAD TRACTOR (A51406)
2016 KENWORTH W900...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
