changing hydraulic fluid-extra cylinders
   / changing hydraulic fluid-extra cylinders #1
troweller
Bronze Member
Kubota 3010, Farmall Cub
it's time to change the hydraulic fluid on the tractor again, which i have done before, my question is what should i do about the implements that have fluid in them? such as loader, which is on the tractor, and backhoe, TnT, hydraulic lift disc, and potatoe digger, which all have fluid in them.
   / changing hydraulic fluid-extra cylinders #2
Don't worry about them.
   / changing hydraulic fluid-extra cylinders #3
Not worth the effort of even trying to change the hydraulic fluid in everything. Just change the tractor and filter and move on.
   / changing hydraulic fluid-extra cylinders #4
The only implements that I worry about changing the fluid in is my larger stuff like my round bailer that actually has it's own sump tank.
Electric Mobility Scooter (A51694)
Electric Mobility...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
TEST YOUR BID BUTTON! (A54756)
TEST YOUR BID...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A52377)
Gravely Pro-Turn...
