Changing HST Filter 4060
/ Changing HST Filter 4060 #1
lzicc
Platinum Member
Pittsburgh, Pa
Kubota B2650
I did my 50 hour maintenance on my L4060. The one thing that it called for was to change the HST fluid filter. The book said that fluid would leak out, but wow, I lost a good gallon or so. Does that sound right? It was very difficult to get the old one off and the new one on since my BH Subframe is right there and there is hardly any room to get your hand in.
/ Changing HST Filter 4060 #2
That fluid loss sounds about right. I lost about 2 gallons when I changed my HST and HYD filters for the 50 hr. change.
After I did mine I saw a post that others had success with to minimize the fluid loss. They hooked a shop vac to the hydraulic fill port and turned it on before changing filters. They claim the suction holds the fluid from running out when just changing the filters. My next change will be the fluid and filters so I won't get to try this trick. Just top off the fluid and be good to go.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 INTERNATIONAL MV607 4X2 26FT NON CDL BOX TRUCK (A59906)
2020 INTERNATIONAL...
Kubota M4700 (A60462)
10' Container w/ Side Door (Damaged) (A60463)
10' Container w/...
2017 Ford F-550 (A55973)
2017 Ford F-550...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A60736)
2011 TROXELL...
