Changing Front axle lube on L245DT
   / Changing Front axle lube on L245DT #1
Tractorbill
Alexandria Twp, NJ
Kubota L245DT
Can anyone help me with the amount of oil needed to fill the front axle and differential case of my Kubota L245DT? Also there are two ports on each side of the axle does it matter how much oil for each side? Is there a seperate fill port for the differential case?
   / Changing Front axle lube on L245DT #2
The ft. axle has two drain points located on the spindels and one fill port on the axle housing. When you refill the ft. axle you want to fill it then either wait several hours or the next day and top it off cause the fluid will take time to drain past the bearings on the spindles.
F-500 POWER PUMP 500HP TRIPLEX POWERED BY 3412 CATERPILLAR ENGINE (A50854)
F-500 POWER PUMP...
2017 Ford Expedition SUV (A50324)
2017 Ford...
2015 FREIGHTLINER M2 (A50854)
2015 FREIGHTLINER...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2015 LINK-BELT 235X3 SPIN ACE EXCAVATOR (A50854)
2015 LINK-BELT...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
