Tires Changing from turf tires on j d 770
   / Changing from turf tires on j d 770 #1
Danny K
John Deere 770
I have a JD 770 with 13.6-16 turf tires on rear and 25x8.5x14 loader tires on front. I need all new tires and would like to get away from the turf tires. Any suggestions without changing rims. I have been told that I could go with 12.4-16 on rear but would need 600-12 on front requiring 12 inch rims which I have been unable to locate. Any help would be appreciated. Danny
   / Changing from turf tires on j d 770 #2
I know the early 790s came with the 6.00-12 rims with ag tires. My 650 uses the same size as well. Just added new tires to the front and they were Carlisle Tru Power 4 ply.
   / Changing from turf tires on j d 770 #3
I would think you can find ag. tires to fit your rims. You should check the circumference of each because JD give the sizes so the ratio is correct when in FWD.
   / Changing from turf tires on j d 770 #4
The 770 and 790 may have shared the same wheels/tires...which is good for any swaps.
So, going to R-1 Ag or R-4 Industrials shouldn't be too difficult...maybe not as cheap as you like though.
Good luck!!
Oh yeah...
Welcome to TBN!!!!
   / Changing from turf tires on j d 770 #5
Is your tractor RWD or FWD? That makes a world of difference as far as your options are concerned. Also, where are you located? I have a full set of FWD R-1 rims and tires that I don't use anymore.
Thanks, but I have been able to work it out. Danny
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2012 MACK PINNACLE (A50854)
2012 MACK PINNACLE...
2013 INTERNATIONAL LF687(INOPERABLE) (A50854)
2013 INTERNATIONAL...
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2018 DODGE RAM 2500 (A50854)
2018 DODGE RAM...
2006 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2006 STERLING...
