Changing from 20 to 40 amp alternator on JD 455
   / Changing from 20 to 40 amp alternator on JD 455 #1
caseyvand
Bronze Member
Dunvegan, Ontario, Canada
I'm planning to change from a 20 amp alternator to a 40 amp alternator on my JD 455 . Physically the change appears to be no problem but the existing wiring to the 20 amp unit only has a 2 wire plug going to it. The 40 amp unit will accept the existing plug ok but it also has a threaded stud beside the plug which I think (but not sure) has to be wired to the Positive terminal on the batery. Has anyone made the same change .......or know......if a different wiring setup is required.
Thanks.....Casey
2011 Land Rover Range Rover Sport 4x4 SUV (A48082)
2011 Land Rover...
Set of Forks (A49251)
1995 JCB 214 4WD Tractor Loader Backhoe (A49251)
1995 JCB 214 4WD...
45055 (A48082)
45055 (A48082)
New Holland 56 Rake (A49251)
New Holland 56...
12-16.5 Tires on Wheels (set of 4) (A49251)
12-16.5 Tires on...
