Changing Ford 4000 Seat?
   / Changing Ford 4000 Seat? #1
mwmst
Ford 4000
Any advice on changing the seat on a Frod 4000.
How hard is it to get off, and what kind of aftermrket seat will replace it?
mwmst
   / Changing Ford 4000 Seat? #2
can you turn a wrench? if so you can turn a couple nuts off studs, or bolts out.
4000 4 cyl will be easiest... no surprises.
4000 3 cyl will have 1 surprise... at least I know the 3000/2000 did. one of the studs that holds the seat on is also a locating pin for the draft hyds inthe 3pt lift... don't freak out if it comes out instead of the nut unscrewing.... just put it back in..
tsc sells a nice blue chair with arm rests and neck support.. has black trim.. looks like it goes perfect for ford and NH tractors. I have um.. 2 or 3 tractors with them... they fit with -0- modifications... the holes inthe bottom mount plate line up perfectly..
Farm Tractor Replacement Seat, Blue - 1238169 | Tractor Supply Company
99$
Can also get a different design from ytmag.. more of a high back padded pan seat probably 120$
http://www.ytmag.com/store/parts/pics/wm_D8NN400BA_BB.jpg
http://www.ytmag.com/cgi-bin/store/model_parts.cgi?SearchArea=FORD&&md=4000&cat=Seats&r=mcats
And of course.. your local NH dealer can get you a seat that fits as well....
soundguy
   / Changing Ford 4000 Seat? #3
As Soundguy mentioned, very easy to get on and off. The locating pin did come out on me, and it WAS a surprise. :D No big deal though.
I tried one of the TSC seats last year on my 3000, and it bolted right on. However, it just didn't work for me. It sits so high my feet didn't touch the floor boards. I tried to get used to it, but it just wasn't safe for me. All of the aftermarket ones I've looked at appear to sit higher than the factory seat, but not all give dimensions so I may be wrong about that. You can still get the original style seat, though they're about twice the price of the others, around $225 if I recall. Haven't pulled that trigger just yet, but my back keeps reminding me.
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2013 John Deere 824K (A51039)
2013 John Deere...
2015 MACK GRANITE DAY CAB (A50854)
2015 MACK GRANITE...
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
