Changing Fluid on Kubota L3010 Front Axle?
   / Changing Fluid on Kubota L3010 Front Axle? #1
Bob64
Northwestern Vermont
Kubota L3010
I am a newbie to TractorByNet. I grew up on a farm long time ago but enjoy the work I can get done around my little 11 acre piece of paradise here in Vermont with a tractor. I own a 2003 Kubota L3010 that I use occasionally for things I couldn't do otherwise so it doesn't get the hours of a true ag tractor. Primarily used for winching out wood, snow-blowing, and moving rocks and bolder.
I changed the front axle fluid (hydraulic) at 400 hours. Now at approximately 600 hours the right front axle seal started leaking and am in the process of repairing it (almost done), I am thinking of converting to 80-90 gear oil (only about five qt capacity) as Kubota states is okay . The question I have is do I have to flush the axle and if so is once enough? I know there will be a small amount of hydraulic fluid left in one hub that I did not change the oil on, maybe a half to one cup or so. Also, how many hours in between flushes?
My reasoning for converting I have read the seals are less likely to start leaking with the thicker oil and of course it is less expensive than UDH2. I would rather not have to replace the seal on the other wheel. Any other suggestions or comments will be much appreciated.
   / Changing Fluid on Kubota L3010 Front Axle? #2
I was inquiring the same and eventually heard back from Kubota dealer here that said a simple drain and fill is fine. But perhaps contact your local dealer and see what they say.
Hope this helps!!
Hope this helps!!
Thanks for taking the time. Yes, it did help. So far so good.
One word.... NO. drain and fill.
Thanks for taking the time. Yes, it did help. So far so good. As soon as the weather warms up I will be checking all of my fluids again as I usually do quite often.
   / Changing Fluid on Kubota L3010 Front Axle? #6
Use a full synthetic 75w-90 gear oil such as Mobil !, Amsoil Severe Gear, or even Walmart Super Tech. Amsoil Severe Gear is what I have in my front 4WD axle.
You are in Vermont.
You are in Vermont.
Thanks for responding. Due to the lapse in time I have already filled the axle and am not at home currently to check what I did use. I am afraid it was not what you recommended although I believe I bought it at the Kubota dealership and paid dearly for the gear oil I did use.
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
2017 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2017 CATERPILLAR...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60430)
KNOW BEFORE YOU...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
