Most farm supply stores will have a fluid fill adapter made by Milton in the tire repair/sir tool section. They are between $10-15.
To empty, as mentioned, determine the size of container you will need to hold the fluid. The following link will help:
Ballast Volume and Weight
- Screw a simple ball valve to the fluid fill adapter the a short length of garden hose. Securing the other end of the hose to the storage container.
- Leave the tire on the tractor. Fluid filled tires are very heavy & hard to handle if dismounted.
- Jack the axle up on the side with the tire you are working with. (The weight of the fluid will cause the tire to sag & will hopefully lower the fluid level to below the top of the rim.)
- With the valve stem pointed up, remove the core & screw on the fluid fill adapter. Hopefully no fluid will escape but to be safe, chemical gloves, goggles, & a closed mouth are smart choices.
- Rotate the tire to where the valve stem is pointed down. Allow the fluid to drain out then rotate the valve stem upwards part way and add air. This will prevent pockets of fluid from being trapped in collapsed portions of the inner tube. Then after reattaching the fluid adapter, rotate the valve stem back downwards & lower the tire to where it is flat on the ground. This will allow the maximum amount of fluid to emptied with gravity.
At this point you can attach a pump to vacuum the remaining fluid or simply break the outside bead lose & dismount the outer side of the tire. You should not have to mess with the inside bead of the tire unless you are replacing the tire.
- Remove the inner tube: Remember the remaining fluid in the tube. Either have a drain pan to catch the fluid coming out of the valve stem as you pull on the tube or re-install the valve core first.
- If repairing the tire, do any repair needed & make sure the inside of the tire is dry.
- Install new tube. You may use the old tube provided it was not damaged & does not show wear around the stem area. DO NOT attempt to use a patched tube with a fluid filled tire. It will not last!
- Remount outer side of the tire.
- Inflate the inner tube to seat the tire.
If using calcium water, remember it is a salt & will damage most pumps unless so rated.
