Changing filters
   / Changing filters #1
jtbuck
North Florida
Massey Ferguson 245
Is there a way to change hydraulic filters on the JD TLD 110 without losing all the fluid; as is there a cutoff somewhere I don't see???
   / Changing filters #2
I'm not sure about the 110TLB specifically but a lot of tractor manuals have instructions for changing the filters with minimal fluid loss. Some instruct to attach a Shop Vac to the oil reservoir filler opening (seal with a rag if needed). This will create enough suction in the system to minimize fluid loss.
   / Changing filters #3
On both of my JDs I'd just changed the filters with minimum loss. If I need to clean the screen I will try the shop vac trick. I talked to the JD service manager and he said it works well.
   / Changing filters #4
Hmmmm - - I've not tried the shop vac method. I've always changed the hydraulic filters when changing hydraulic oil. Besides - - I have a BIG shop vac - the kind that could suck golf balls down a garden hose and I'm just afraid it could result in a really big mess. I can see ruined shop vac - hydraulic oil sprayed all over the place - potential for ignition. I'll do it my way.
Besides - just drain down the hydraulic oil - change the filters - pour the hydraulic oil back in. On your TLD 110 its 15 gallons.
   / Changing filters #5
oosik
Oil should not be near the filler opening so couldn't be sucked up into the shop vac.. just sayin...
If yours can suck golf balls down a garden hose, that will make a great video and would like to see it.. ;)
   / Changing filters #6
Beenthere - - A WHOLE LOT of thing should never happen - but for some strange reason - they do. Golf balls & garden hoses - excuse my literary license. I saw a video on that once - it was a fake, but very funny. Certainly was not a shop vac sucking' those golf balls - wasn't on the kiddie network either.
2021 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2021 Ford F-250 XL...
2021 Simex padding bucket, 8-9 ton class, like new (A52384)
2021 Simex padding...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
City of Buckhannon - 2005 Volvo Garbage Truck (A52384)
City of Buckhannon...
2013 VOLVO VNL64T670 TANDEM AXLE SLEEPER (A53426)
2013 VOLVO...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
