Changing Coolant
   / Changing Coolant #1
Strongman
Southeast Michigan
The manual states to change the engine coolant after the first year. Is there any reason to do so if the tractor has less than 100 hours on it? I never really run the tractor too hot. I can understand changing the other fluids due to the shavings but why the coolant?
Thanks for your comments
3820 FEL BL20A
   / Changing Coolant #2
I wouls stick with the program....The antifreeze can become acidic thus losing its ability to protect your very expen$ive internal components.
If you have pH paper you can check and see if your ph7 neutral.
my .02
   / Changing Coolant #3
Also, the coolant can have shavings in it from either the water pump or internal cooling passages. It just wont be near as much as the rear end. You should just go ahead and change it.
   / Changing Coolant #4
Coolant deteriorates with age, not use, so I would follow the manufacturers recommendation. The coolants available in the US are of a better quality than those made in other parts of the world and will last longer. Buy the pre mix kind, so you don't have to buy distilled water to mix with the coolant and you will know the mix is proper. Flushing shouldn't be necessary on a new tractor and the little left over in the block will mix and not cause any harm. Dusty
   / Changing Coolant #5
All modern coolents contain a lub for the water pump. As the coolent ages this lub becomes less effective. I'd replace it per the owners manuel this time and in the future as often as the directions on the coolent container suggest.
2007 Reitnouer 40 Ton T/A Flatbed Trailer (A49461)
2007 Reitnouer 40...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
2016 Ford Escape AWD SUV (A50324)
2016 Ford Escape...
2021 Takeuchi TL12V2 Skid Steer (A51242)
2021 Takeuchi...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
2016 CHEVROLET SILVERADO 2500 HD CREW CAB TRUCK (A51243)
2016 CHEVROLET...
