changing boomer filters
   / changing boomer filters #1
deepsnow
Bronze Member
bayview township, bayfield co. WI
NH TC25D
On an unusually warm January day I decided better today than a cold day to do my 50 hour filter/fluid changes. Only one problem was the excessively tightly screwed on break-in oil filter. One surprise. The amount of hydro fluid that came flowing down my arm upon loosening the filter ( the long one located underneath the backend of the tractor). I ended up having to replace more than +1liters of hydrofluid. The system was depressurized. After the inital release of fluid it basically stopped. Is that "normal"? The location of this filter on a TC25D seems relatively exposed. I will be more careful when backing this unit up in any brushy/tall grass area and uneven terrain.
   / changing boomer filters #2
I just did my 62 hour service today. I was at my dealers yesterday picking up all the filters and fluids that I would need. I asked the guy who sold me the tractor how much hydraulic fluid I would need to do the 50 hr service. He said a quart should do it but I better grab two just to be sure. Another employee standing nearby said that he almost used a gallon the day before when he did a 50 hour service on site for somebody. I bought a gallon of the stuff and I ended up needed about 3/5ths of it. So how much did you pay for all your filters? I still need to do my fuel filter, I don't quite understand the directions yet so I will wait a while longer.
Spence
   / changing boomer filters #3
I used 9 gallons, but I went ahead and changed my hydraulic fluid (even though the interval was at 250 hours). My fluid looked a bit dirty to me, so I went ahead and changed it. Call me kooky, but I grew up learning that it is really hard to *over* maintain a piece of mechanical equipment.
As far as fluid loss when changing the filter itself, I'd say about 1 to 1 1/2 quarts when I took the filter off. Mine were not especially hard, but I had the correct sized filter wrenches for all the filters. Most of them were "2 1/2 hand" tight, meaning, a small flexible belt wrench was quite adequate to the task. Where I had problems was the clearance between the linkage, frame, and wheel trying to get the filter out. I have a 35D, but, at least fromt he illustrations, the filter arrangement is the same.
As far as the filter being exposed, the class III boomers have it up fairly high, and insde of a rear wheel, just above the frame, so clearance is no problem.
Hope you had fun servicing the tractor - we had a nice day and got it done in about two hours, including the hyd fluid change.
Regards,
Steve
John Deere 400 Rotary Hoe (A50514)
John Deere 400...
18003 (A51691)
18003 (A51691)
2014 Chevrolet Tahoe SUV (A51694)
2014 Chevrolet...
JOHN DEERE 3 BOTTOM PLOW (A51243)
JOHN DEERE 3...
5' ATV Harrow (A50515)
