Changing a damaged hydraulic oil filter
   / Changing a damaged hydraulic oil filter #1
HCJ
upstate South Carolina
Kubota M6800 4WD
My Kubota M6800 has two hydraulic filters side by side underneath. I noticed a leak and when I crawled underneath the tractor, found one filter bent. Guess it was damaged by a stick or stump from below. It seems to be leaking from the seal, so I assume the seal was distorted. My question is when I remove this filter, how much hydraulic fluid will I lose if I work fast? My capacity is 40 quarts. Will it pour out or trickle out? Before I replace this filter, just was curious as to what to expect. Am I going to get a facefull of fluid? Any tips?
   / Changing a damaged hydraulic oil filter #2
My Kubota M6800 has two hydraulic filters side by side underneath. I noticed a leak and when I crawled underneath the tractor, It seems to be leaking from the seal. Any tips?
Have you tried tightening it up a little more????
   / Changing a damaged hydraulic oil filter #3
If tightening doesnt work, on some tanks you can put a plug in the filler without a vent. if no air can get into the tank not much oil should get out. Or a vacume may work.
   / Changing a damaged hydraulic oil filter #4
Check yer hyd schematic in yer service manual.. see where the filters are in the plumbing.. that will let you know if oyu will see lots of tank pressure or not.
soundguy
   / Changing a damaged hydraulic oil filter #5
Do they lay on their side ?, you will probably get quite an amount. 2 qts or so. Not so much if they were upright.
Ether way, I'd get a catch pan and replace. And don't stick your face in the way when you unscrew them.:rolleyes:
   / Changing a damaged hydraulic oil filter #6
Yes they lay on their side. Thanks for the replies. I'll just have to work fast and hope for the best!
   / Changing a damaged hydraulic oil filter #8
2 user names ?
Sometimes we South Carolinians have two usernames, one for the countryboy and one for the redneck countryboy!!! :) LOL.
UNUSED AGT MX15RX EXCAVATOR (A51243)
UNUSED AGT MX15RX...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
2012 Ford Expedition XLT SUV (A51694)
2012 Ford...
Kinze 600 Grain Cart (A52349)
Kinze 600 Grain...
2014 Dodge Journey SUV (A50324)
2014 Dodge Journey...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
