Changed stator, ran, died, now backfired
   / Changed stator, ran, died, now backfired #1
ctwith3
Westchester County, NY
Deere L118
History:
Had to charge the battery after use so I bought a new voltage regulator, but that didn't fix the problem.
Replaced stator and flywheel shear that broke when taking off the flywheel, charged battery, tractor started and ran fine.
Next day, today, tractor won't start. Kept trying and it backfired. Removed the flywheel and checked the stator- it's in tight and it looks great.
Help!
   / Changed stator, ran, died, now backfired #2
Since I presume this has electronic ignition system are you getting spark to the plug? It's possible while removing the flywheel you changed the air gap for the ignition trigger assembly. Do you have a manual or know what this is supposed to be set at?
   / Changed stator, ran, died, now backfired #4
Which engine brand and size? Horizontal or vertical shaft? Mostly just curious.
Assume the key was not sheared the second time flywheel was removed. ??
   / Changed stator, ran, died, now backfired #5
It might help if we knew what tractor you have and what engine is in it.
Also I have no idea what a flywheel shear is. Please explain. Provide photo if possible.
Richard
Deere L118.
Briggs& Stratton Innotek 22 hp
Shear key as in flywheel shear key, is what keeps the flywheel timing static.
   / Changed stator, ran, died, now backfired #7
This winter had a B&S engine that backfired and found flywheel key sheared.. so thought that was the cause and problem. Put new key in and backfired again.. new key was sheared again.
Finally found the root of the problem.. that a very small spring that held the compression release was broken. This fixed, and solved the problem. Now admit this was a single cyl. 9 hp, but may be something to consider.
You didn't say if the second time removing the flywheel, that the key was not sheared.
   / Changed stator, ran, died, now backfired #8
Agree with beenthere, I am almost certain that the flywheel is not in the correct rotational position.
Question is, why was the key sheared in the first place?
Did the mower blades his a solid object?
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
2015 DODGE RAM...
2017 Ford F-150 Pickup Truck (A53422)
2017 Ford F-150...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
