Oil & Fuel Changed oil
   / Changed oil #1
JDpuppy1
Buffalo ny
Just changed my oil yesterday---I have a 3520. Put 5 qrts in the tractor and the oil level is high on dipstick. Could the dipstick be wrong??
Let drain for 1/2 hour-45 min. Calls for 5.1 qrts. Ran the machine for 10 mins then checked. Same thing. any thoughts??
   / Changed oil #2
I would remove enough oil to get it back to full rather than over full. Once you do this, tell us how much over full it was.
Joe
   / Changed oil #3
5.1 quarts would be the total system capacity. It seems obvious that more an 0.1 quart remains in the system after draining. Without measuring what you drained out there is no easy way to determine how much fresh oil needs to be put back in. The method most of us use would be to fill it up with 4 quarts and then start checking the dipstick, add, wait, check, repeat. It's a pain but it's how I've had to do it on my 2720. Even then, it is very easy to overfill. On occasion I've had to use a small oil sucker to remove some excess oil. It made the process painless.
   / Changed oil #4
Questions:
Did you replace the oil filter?
Did you drain the oil on a level surface?
   / Changed oil #5
I suppose the dip stick could be wrong....as well as a misprint. My 3520 calls for 4.3L with a filter.
   / Changed oil #7
G'day Mate and welcome to TBN from Downunder.
What jgayman said. It's a pain in the arse but the 5.1 quarts is the 'wet up' capacity & you'll never drain the entire amount. As we say in Aus, "it's a trick for young players."
   / Changed oil #8
I think I mis-read this. I thought the OP was talking about the transmission oil. But obviously at 5 quarts it would be the ENGINE oil. Duh! It's the transmission oil that is difficult to get the level correct. Although I suspect the issue is the same in that you would never be able to add the full capacity back in.
Did you change the filter?
   / Changed oil #9
How did the dipstick measure before the oil change?
did you keep it on the full mark or just not check it and now that you put new oil into it its wrong
2007 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2007 STERLING...
2019 JOHN DEERE 317G SKID STEER (A51242)
2019 JOHN DEERE...
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2015 Ford F-250...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
2014 Doosan DA30 (A51039)
2014 Doosan DA30...
