Changed hydraulic filter now hydraulics don't work
/ Changed hydraulic filter now hydraulics don't work #1
terrymarine
Friendship
Deere
Fairly new owner of 2016 New Holland Workmaster 50. At 100 hours I changed the hydraulic filter. The filter was purchased from a NH dealer. I followed the owners manual directions. It did not say to fill the new filter prior to replacing it. After replacement the hydraulics, both loader and 3 point don't work. Can I bleed the system? I thought this would have been a simple job.......if you all have any advice for this ignorant but well meaning tractor owner I would sure appreciate it.
/ Changed hydraulic filter now hydraulics don't work #2
You probably have a filter plus full of air in there, can you put a vacuum (like a shop vac) on an orifice to prevent oil spillage then fill the filter?
I've had minor problems when changing a cylinder but they worked out.
/edit
You might want to try DLTTrekkers solution first.
Sir thanks for the quick response, I'll try it first thing in the morning.
/ Changed hydraulic filter now hydraulics don't work #4
loosen the thinner of the 2 hoses at your hydraulicpump....start your engine and when oil squerts out shut down and make sure o-ring is still in its groove ...then retightern hose.
2024 SILVERBACK SB50WCH 50FT TRI/A GOOSENECK CAR HAULER TRAILER (A59910)
2024 SILVERBACK...
2007 FREIGHTLINER M2 4X2 S/A STAKE BED TRUCK (A59910)
2007 FREIGHTLINER...
2012 CATERPILLAR 259B3 SKID STEER (A64279)
2012 CATERPILLAR...
2014 John Deere 644K High Lift Articulated Wheel Loader (A61572)
2014 John Deere...
2021 John Deere 320R Loader (A63116)
2021 John Deere...
Rhino 7ft Blade (A63118)
Rhino 7ft Blade...
