change kph to mph
   / change kph to mph #1
sailingsolo
hope, me
kubota L47
kubota gives you lots of information in the operator's manual, however, it doesn't give you enough or i didn't read enough.
anybody know how to change the display in the intellipanel on a 2018 kubota l47tlb? thanks.
am not racing the tractor so i don't need to know how fast i am moving but would prefer the display to be mph and not kph.
   / change kph to mph #2
Did you buy it in America? If so I would assume that it can read in MPH. Probably a button to switch between the different units but IDK as I don't have a Kubota. If you bought it from outside the U.S. from say Canada then I could see it possiby only reading in metric units but again IDK for sure. It would be lousy if you had to buy some U.S. market dash for it but I doubt that's the case if you bought it in the U.S.
If you can't change units and to convert the numbers then 1 KPH =.621 MPH so just multiple your KPH by .621 to give you your MPH.
   / change kph to mph #3
I can't believe that your OP manual doesn't tell you how to switch. My dash has a push button - but if yours was that simple, you would not be here asking. In my OP manual it is in the Instrument Panel and Controls section. It says - "push button".
2006 Ford F-150 Pickup Truck (A51692)
2006 Ford F-150...
Pallet of (4) 10 Lug Misc Wheels (A51573)
Pallet of (4) 10...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2016 TROXELL 130BBL VAC TRAILER (A52472)
2016 TROXELL...
LATE MODEL JOHN DEERE EQ. AUCTION LOT NUMBER 1 (A53084)
LATE MODEL JOHN...
