Oil & Fuel Change hydro fluid in NH1925
   / Change hydro fluid in NH1925 #1
jjbyas
It is my first time changing hydraulic fluid/hydro transmission fluid in my NH1925. The owners manual says to drain, change two filters, refill and that's it. Any advice from anyone? My other question is whether to use NH fluid. I am a long ways from a dealer and the other option is NAPA. Thanks.
   / Change hydro fluid in NH1925 #2
Hope someone answers you soon. I changed mine today in my TN75DA. Four different drain plugs, changed two filters, then refilled with 12 gallons of fluid, which should be about 1/2 gallon short, but measures over full because it hasn't yet pumped through the system. 3-point doesn't work, front loader doesn't work, however the shuttle does work allowing the tractor to go forward and in reverse. I let it run for 30 minutes thinking it would start working but hasn't. Good luck with yours.
2010 Ford Fusion Passenger Car (A51694)
2010 Ford Fusion...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
2007 PETERBILT 379 (A52472)
2007 PETERBILT 379...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A51572)
2007 Isuzu FTR...
