Change hyd, oil
   / Change hyd, oil #1
mayer2323
Whats the recomended hyd oil change hrs. or time on a ford 841 ? I usually do about 30 to 50 hrs, a year.
   / Change hyd, oil #2
600hrs or every year for a worker tractor.. for a parade queen.. I'd go 2 year / 600 hrs.
Since your hydro oil likely stays pretty clean.. this just helps you get moisture out.. etc.
if you have remotes and use alot of remote equipment with questionable hyd oil.. i'd change more often..
( 2ys for your use probably fine )
soundguy
2015 Ford F-450 Bucket Truck (A53117)
2015 Ford F-450...
2021 Harley-Davidson FLHP Motorcycle (A51694)
2021...
2025 K4525G UNUSED Double Garage Steel Barn (A53117)
2025 K4525G UNUSED...
2011 Case 3020 30ft Flex Draper Head WITH TRAILER (A53473)
2011 Case 3020...
2025 K0520 UNUSED (5) Welded Wire Mesh Roll (A53117)
2025 K0520 UNUSED...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
