kenlip
- Joined
- Nov 3, 2017
- Messages
- 225
- Location
- NSW Australia
- Tractor
- Kubota MX5100 with Challenge FEL and 4:1
A dealer has recommended the Challenge 2821 instead of the Kubota LA854AU-B to go onto a new Kubota MX5100
Does anyone have experience with the Challenge brand?
Challenge 2821 specs:
Horse power range (approximate) 45-60
A - Maximum lift height to pivot pin 2840mm
B - Maximum lift height under level bucket 2550mm
C - Clearance with bucket dumped* 2000mm
D - Reach at maximum lift height** 1060mm
E - Maximum dump angle 58ー
F - Reach with bucket on ground*** 1940mm
G - Maximum rollback angle 49ー
H - Digging depth**** 150mm
J - Overall height in carry position 1550mm
K - Maximum rollback angle at maximum lift height 49ー
Lift capacity at pivot pin - Ground level 1490kg
Lift capacity at pivot pin - Maximum lift height 1242kg
Lift capacity at 800mm from pivot pin - Ground level 1350kg
Lift capacity at 800mm from pivot pin - 1.5m lift height 1306kg
Lift capacity at 800mm from pivot pin - Maximum lift height 900kg
Bucket rollback force at ground height 1000kg
Tractor pump pressure (will vary depending on tractor model) 185bar
Maximum Frame Weight 368kg
Mechanical Self Levelling Yes
Easy Detach Loader Frame Yes
Manual Locking Attachment Quick Coupler -
Auto Locking Attachment Quick Coupler Yes
Kubota LA854AU-B Front Loader Specifications
Maximum Lift Height (Pivot pin) mm 2863
Clearance w/Attachment Dump mm 2255
Reach @ Maximum Height mm 570
Maximum Dump Angle deg. 45
Reach w/Attachment on Ground mm 1919
Maximum Rollback Angle deg. 43
Digging Depth (When Bucket is Level) mm 177
Overall Height in Carry Position mm 1410
Material Bucket Width/Weight mm /kg 1830 / 150
Lift Capacity (500mm forward) kg 800
Raising Time to Full Height w/out Load sec. 4.4
Lowering Time w/out Load (powerdown) sec. 2.8
Attachment Rollback Time sec. 1.9
Attachment Dumping Time sec. 1.5
Rated Flow l/min 37
While they are not using the same criteria, the lift capacity seems to be significantly higher for the Challenge, unless I am reading/interpreting incorrectly.
Would you agree with the dealer and go for the Challenge, or stick with the Kubota.
Any other reason/s to pick one over the other?
Ken
Rated Flow l/min 37
Ken
