Chainsaw Question
   / Chainsaw Question #1
hunterridgefarm
Veteran Member
Western NC
Kubota L3130DT, Kubota L185DT, JD LX277
I have a Husqvarna Rancher 18" bar that has cut many trees down over the last 8 years. I took ten good size pines down over Thanksgiving. The saw started speeding up when in idle mode once it got hot and eventually died. Once it cooled off it would start, run for 20 min then start to speed up on idle, kind of like they do when they are running out of fuel.
I have check everything I know to check but cannot find the problem. Can someone tell me what the cause and fix is?
I have a big Stihl that is 35 years old and use it to take trees down and cut into logs but like to use the Husky to trim limbs since it is a little lighter and has a chain brake.
I have 9 oaks and 3 more pine I need to take down this weekend. Trying to clear out around the site for workshop build that hopefully will start by Feb. Due to me being on top of a ridge and the wind direction these trees pose a risk of falling on the workshop.
   / Chainsaw Question #2
Gas tank vent?
The symptoms you describe (speeding up) is cause its leaning out from fuel starvation.
If the vent isnt clear, it will dry to draw an ever increasing vacuum until it gives up.
When it does it again, try cracking the gas cap and see if it comes out of it.
   / Chainsaw Question #3
LD1 is probably right on. Vapor lock was the first thing that came to mind.
   / Chainsaw Question #4
It's possible you may have an air leak that's leaning out the fuel making it run faster? If this condition is not identified and corrected (whatever is causing it), you'll eventually seize the motor & trash the saw.
   / Chainsaw Question
That's a good start. I don't think I checked the fuel cap vent:eek:. I took everything else apart, but the vent makes sense. I will give that a try.
   / Chainsaw Question #6
Please let us know what it took to fix it. Thanks
   / Chainsaw Question
I will let you know what the fix is. However it will be Saturday before I can run it enough to know.
   / Chainsaw Question
It appears it was/is the gas cap. Easy fix, thanks!!
   / Chainsaw Question #9
Thank You, I will keep this in mind should it happen to me.
   / Chainsaw Question #10
Glad you got it running.
I wish I could get out and cut some wood. Just too darn cold for the next several days:banghead:
2020 CATERPILLAR 336 EXCAVATOR (A51242)
2020 CATERPILLAR...
2014 Jacobsen AR3 Commercial Mower (A50322)
2014 Jacobsen AR3...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
KOMATSU WA450 LOADER (A51242)
KOMATSU WA450...
2006 TOYOTA Highlander SUV (A50324)
2006 TOYOTA...
2021 Doosan DX350LC-5 Hydraulic Excavator (A50322)
2021 Doosan...
