Chainsaw Gas
   / Chainsaw Gas #1
Rat Rod Mac
Has anyone run 100 octane aviaton gas in their chainsaws. It has lead in it. I live close to a small airport and am getting tired of junk gas, so I thought I might try some av. gas, but did not want to until I checked with you guys. Any suggestions are welcomed. Thanks. RRM
   / Chainsaw Gas #3
No... but from reading the Forums... I thought I was going to have all kinds of trouble with my "New" Stihl saw.
A little over two years ago... a large tree fell during a windstorm up in Olympia WA where I was staying. Being 800 miles from my tools and wanting a Stihl saw... I bought one and had the tree cut-up in no time...
Planned to do some more work on the weekend and then got the call that I was needed at the job... 800 miles away.
My new MS 250 C-BE saw sat the entire time in the basement with a tank full of now 2 year old gas... it started on the 4th pull and I spent the day clearing fallen trees and used the rest of the gas I had mixed 2 years before...
Maybe I was just lucky?
I used the Stihl oil the dealer had given me and the saw and fuel were stored in a cool, dry place... probably about 50 degrees year round.
   / Chainsaw Gas #4
You won't have any problems running AV gas. Additional benifit is all AV gas is alcohol free. Downside is cost. Are you sure it's leaded? The AV gas around here is unleaded.
   / Chainsaw Gas
A pilot friend said it was leaded. I will find out when I go to buy some. He said it goes for over four bucks a gallon, but for all the more I will use it would be worth it if the saw runs good. Thanks for the replies. RRM
   / Chainsaw Gas #6
You're talking about 100 LL fuel . It is leaded ,but not to the extent of fuels of yesteryear .
I doubt that You'll gain anything from using it over a good premium fuel however .
But then it's Your saw , and Your $ .
   / Chainsaw Gas #7
Premium here is going for $3.69 a gallon at the near by Shell Station... $4 a gallon doesn't sound too expensive for alcohol free fuel for the saw.
   / Chainsaw Gas #8
Get the avgas and thank your lucky stars you have the option. It's the best fuel we can get, and the lack of ethanol is a real bonus.
Chilly
   / Chainsaw Gas #9
Forgot to mention one thing. If you have a newer (post 2006) saw that meets emission requirements for CA, then don't use leaded fuel. These saws (and all other 2 strokes) have catalytic converters (similar to a gas engine car) and the lead will clog it pretty quickly.
I agree with the others that premium auto gas is sufficient (octane wise), but I知 get concerned with the alcohol levels. In SE PA we are seeing alcohol levels greater than 15%. High alcohol raises the cylinder temp, and can melt a piston. The Stihl dealer that I use showed me one. They have an alcohol test kit, and measured the alcohol at 26%. The saw owner had been adding drygas which caused the high alcohol level. Unknown how much was in the gas at the pump. I had them measure fresh 92 octane and it was 16%. So, I've been using marine grade Stabil (blue color) which is suppose to counteract the effects of the alcohol. I also use fully synthetic 2 stroke oil. I put about 15 hard hours a week on my portable 2 stoke equipment and haven't had any problems. So, I'm assuming what I'm doing is working.
Thanks Mike.
   / Chainsaw Gas #10
Mike;
Not to start a argument, but IMHO don't think alcohol, itself, melted the piston. Alcohol burns much "cooler" than gasoline. In my bike racing days you had to "jet up" to get power from alcohol. What probably happened was, as the alcohol content went up in the fuel, the oil mix ratio stayed the same. The lack of enough lube probably fried the piston through excessive friction. With alcohol in two strokes you really have to put in lube, like 30:1 or 28:1. Nothing like the sounds and smells of a two stroke on alky at full throttle.
SimS
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
CATERPILLAR VC60DSA SHOP FORKLIFT (A52472)
CATERPILLAR...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2020 Freightliner M2 106 S/A Dump Truck (A50323)
2020 Freightliner...
