Chains chains R-4 , backhoe and 240 loaderTc -34
   / chains R-4 , backhoe and 240 loaderTc -34 #1
tmac2
TC 34 hydro is there enough clearance for chains on this setup
looking to put chains on to prevent lateral sliding, tractor has a subframe mount for backhoe and a loader , Tractor is a TC-34 Hst R-4 tires 15x19.5, there is not a lot of room between tire and subframe , any one have any experience with chains and this setup I hate to order chains and not be able to use them, your thoughs are valued in this matter -Tractor is a TC-34 Hst
   / chains R-4 , backhoe and 240 loaderTc -34 #3
buy your chains yet? better a late reply than none! I had the same problem with my tc45d I thought there was not enough clearence for rear chains so i put a set on the front that i purchased thru my dealer, VERY BAD! to MAKE A LONG STORY SHORT. I found a place on line in PA. I put 2 link v bar chain on the rear, great investment! no hopty hop either. send me an e-mail cause ill have to look up the company , a quick guess would be Tire Chains by TireChains.com
kind regards
Blake
ps that is correct, click on farm tractors they will need the tire size
   / chains R-4 , backhoe and 240 loaderTc -34 #4
click on my profile you can the chains on my tractor
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
Parker 250 bu Gravity Wagon / Seed Tender (A50515)
Parker 250 bu...
2008 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2008 CATERPILLAR...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
1049 (A50459)
1049 (A50459)
