Chains Chains or Straps??
   / Chains or Straps?? #1
MDSteve
Clements MD
Kubota 3710
I was wondering what everyone is using to pull stumps and tress around with. Most stumps are are dug up with the fel and just need to be dragged to the burn pile about 700 feet away. They are usually too big for the FEL to handle.
Steve
   / Chains or Straps?? #2
If all you are doing is dragging stuff around I'd definitely go with chains. Straps will wear pretty quickly under those conditions /w3tcompact/icons/smile.gif
   / Chains or Straps?? #3
3/8 chain is indestructable in that application
   / Chains or Straps?? #4
I guess I have to be the first dissenter on this one. I have used straps for years. If you use a high quality strap with a high load capacity it will perform right up there with chain. I haven't had any problems with wear. I guess you could argue that over time a chain will outlast a strap, but my heaviest strap is now 10 years old and still going. The advantage is that a strap is lighter and easier to carry around. It manuvers around groups of logs better than chain. It tightens better than chain when you start pulling. And perhaps best of all, it is much safer should a breakage occur. There is another thread out there that recently discussed what can happen when a chain breaks under extreme load.
   / Chains or Straps?? #5
straps are made to recover stuck vehicles and do so by stretching and then slingshotting the stuck vehicle free, it is then if something breaks a deadly projectile is born.
   / Chains or Straps?? #6
Not all straps are made to recover stuck vehicles. Industry uses many straps to lift items with cranes. You will see more industrial grade straps in manufacturing applications than chains.
I also use straps with my tractor as well as chain. In my opinion, it depends on the use and circumstances
   / Chains or Straps?? #7
<font color=blue>it is much safer should a breakage occur</font color=blue>
Be very careful out there! Chains, straps and cables are nothing more than big springs when put into tension. The amount of energy stored in each is proportional to the load and the deflection or stretch. For a given load, the strap is designed to stretch the most thus it will store the most potential energy. All that energy has to go somewhere if it breaks /w3tcompact/icons/shocked.gif
Bottom line is to be extremely careful when lifting/pulling with anything /w3tcompact/icons/smile.gif
I have been using a 2 inch strap. It has broken on me a few times and I have been tieing new loops on the end. It has never streched to the point where it pops back at me. I guess I will need to get a larger strap or some chain. What size chain and straps are we talking about?
Thanks for all the help.
Steve
   / Chains or Straps?? #9
Steve
You might see if there is a place close to you that makes industrial straps. I have several in different lengths and strength. I had them made and had hooks added to them before they were stiched. They can be of many types and styles. You usually are limited by what you can find in most stores that carry straps.
   / Chains or Straps?? #10
Tony,
<font color=blue>my heaviest strap is now 10 years old </font color=blue>
Fabric degrades with age. I don't know how long a tow strap lasts but be careful with that 10 year old strap. /w3tcompact/icons/shocked.gif
Chris
UNUSED FUTURE 4 GAUGE 25' JUMPER CABLES (A51243)
UNUSED FUTURE 4...
JOHN DEERE 250 SKID STEER (A51242)
JOHN DEERE 250...
Cub Cadet GT2550 Riding Mower (A50515)
Cub Cadet GT2550...
2016 VOLVO EC300EL EXCAVATOR (A51242)
2016 VOLVO EC300EL...
2022 CATERPILLAR 335 EXCAVATOR (A51242)
2022 CATERPILLAR...
Yale Veracitor 135VX Yale 12,150lb Forklift (A50322)
Yale Veracitor...
