Chains Chains...opinions
   / Chains...opinions #2
I've run v-bar chains for years and never had any problem with them flipping over.
   / Chains...opinions #3
Hi Tom,
I just bought and installed a set of "Duo-Grip" (H pattern) chains for my 5030. I paid $382 (14.9 x 26) at a local Les Schwab dealer and they are very beefy. I pondered the "V Bar" and did not think the price bump (I seem to remember about $100) was worth whatever purported advantage they might possess. Tirechains.com has the v bars for the same price I paid for the non-V Duo-Grip, but the shipping would still eat my savings.
We get big snow, lots of ice, and fairly cold (late Dec and Jan is always minus degree time). We are snow and ice covered now, and so far with the chains on, I have plowed about 4 miles of road and pulled out a large truck that was stuck.
No loss of traction or even a hint thereof.
   / Chains...opinions #4
Ladder vbar type chains can make for a very rough ride with small tires.
   / Chains...opinions #5
I've been considering chains for my JD4100 4WD Hydro. There are several types I can use on the rear tires, but a very limited choice for the front. Basically just a cross chain type.
Do I really need chains on all four wheels, or just the rears? I can see where front chains would help with steering.
   / Chains...opinions #6
You shouldn't put chains on the front, it doesn't allow for slippage between front and rear axles. On my 4110 there would also be major clearance issues. I can understand your wanting better steering though,with chains on the rear and snow under the front it seems to have a mind of it's own. I steer with the brakes when pushing snow. It adds to the fun
If you know any retired independent truckers tou may be abke to pick up a set of chains on the cheep,just have to cut them down to fit.
   / Chains...opinions #7
I made some up for my Cadet from old car chains. You could probably combine two sets of those for most CUT tires. The repair links to put them together are about $1.50 each around here.
   / Chains...opinions #8
Lots of truck shops and trucking companies have tons of used chains that are of no use to them. After they have so much wear, they quit using them. They can be bought for almost nothing or sometimes they will even give them away.
   / Chains...opinions #9
ttowne66 said:
Guys
Tire Chains by Tirechains.com .See a bunch of different versions here. Just wondering if anyone has experience with any of these stlyes. V-bars look good but if they flip over the advantage is gone. Opinions/thoughts welcome!
Tom
Winter newbie here
Do I need chains??
Year: 2004 Make: Sterling Model: Acterra Vehicle Type: Truck Mileage: Plate: Body Type: Trim Level: (A51692)
Year: 2004 Make...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
20305 (A51694)
20305 (A51694)
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 108,542 (A50324)
Year: 2017 Make...
John Deere 693 Corn Head (A50514)
John Deere 693...
UNUSED FUTURE MINI SKID STEER STRAIGHT DIGGING ARM (A51244)
UNUSED FUTURE MINI...
