Chains Chains on a 2210
   / Chains on a 2210 #1
wickman
Bronze Member
Central Ohio
JD2210
My first winter with the 2210 is here and I'm wondering if I'll need chains to move the snow around. I'll be using the FEL and I have turfs. If chains are in order then is there a specific part number to ask for? I'm assuming that you'd only put chains on the rears but who knows.....
Thanks, wickman
   / Chains on a 2210 #2
My 2210 has the FEL, 5 ft rear blade and 2-50 lb wheel weights on each rear wheel for 200 lbs total. I have moved a lot of snow with no chains. The 4wd works wonders.
I would try it first without. I think the only need for chains is steep slopes with ICE, otherwise the 4wd gets you through.
   / Chains on a 2210 #3
I have to agree with Fgross. I put rear chains on my 2210 'cus they were thrown in with my snowblower. I blow snow mostly in 2wd and never spin a wheel. I do have an 8% grade to plow and when it does the freeze/thaw cycle, it becomes a skating rink.
On flat ground I wouldn't worry about chains.
   / Chains on a 2210 #4
I don't know how steep my asphalt driveway is but when it gets icy I'm afraid to drive on it if that's any indication. I move snow with a snowblower and no chains. With FWD engaged I can go up that slope forwards or backwards with no problem. I haven't tried the FEL but I sure wouldn't put on chains and scratch up expensive concrete and asphalt unless there was no other option. That's one reason I bought the 2210 instead of the X series. Besides, the chains on my old tractor didn't help much on ice - but it was 500 lbs lighter too!
   / Chains on a 2210 #5
I have been pushing around snow with my 2210/FEL/turfs the last couple of weekends. I would have to guess that my drive is about a 3% grade, and I have no problem in 4WD. 4WD makes all of the difference. I'm not even using any addtional ballast in the rear other than the standard filled tires. In 2WD I definately slip around quite a bit more, and I only switch to 2WD to do final cleanups.
So far, these have been fairly wet snows, not really cold powder. Until I see a problem, I don't think I'll be buying chains. However I'm still on the fence about getting a blower instead of the FEL. It doesn't take a lot of snow to start making big piles.
Landoll (A50657)
Landoll (A50657)
John 4 x 4 cart (A50323)
John 4 x 4 cart...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
Hyster H155XL Forklift (A48837)
Hyster H155XL...
Club Car (A50324)
Club Car (A50324)
UNUSED CFG INDUSTRIAL SSECAG-Y AUGER BITS (A51244)
UNUSED CFG...
