Chain hooks?
   / Chain hooks? #1
VAMountains
Bronze Member
Kubota L4740 HSTC
Please excuse the stupid question, but what are the primary uses for chain hooks on a loader? I figured out the "to hook chains to" part all by myself, but I'm curious how/why people use them? My new bucket is being installed later in the week, and I may have hooks put on. Thanks in advance!
   / Chain hooks? #2
Lifting objects. Hook a chain around the object and connect it to the chain hooks on the bucket and lift. I have used mine to lift inplements on and off trailers and delivery trucks. I am sure there are many more uses for bucket chain hooks.
   / Chain hooks? #3
I just used the chain hooks on mine to set a 2' x 2' x 2' concrete catchbasin. The weight of the catchbasin is near the capacity of my LA402 loader (I could only lift it a couple of inches) I slipped a steel rod thru the two lift holes and hooked a chain around it and bucket hooks and lowered it into the hole. I had put sand in the bottom of the hole to aid in leveling the basin so I picked up the basin repeatedly and dropped it from a couple of inches to level and set it.
   / Chain hooks?
Very helpful, thanks. I'll ask my dealer to weld hooks on the loader I'm getting delivered shortly.
   / Chain hooks? #5
I use them a lot to load implements on the trailer that are too big to fit in the bucket.
Lately, I've been helping a buddy clean up in and around a warehouse with 30 years of outdated industrial equipment laying around. A lot of times the equipment is half buried and I can't get my bucket under it, so we tie on the chain and lift.
They sure make it easier to hook/unhook than wrapping the chain around your bucket, and they keep the item further away from the front of your tractor to keep it safe(r) from impacts.
   / Chain hooks? #6
Another use for chain hooks on the FEL is to pull a chain going in reverse.
Especially if you do not have a drawbar, this is much safer. If the tractor starts to overturn going in reverse, the rear wheels come up off the ground and you will lose traction rather than overturning.
   / Chain hooks? #7
You will find the hooks invaluable. In addition to not allowing the chain to not scrape the paint off your bucket, they will not allow the chain to slip either up or down the bucket when you are trying to move something. My dealer welded (3) 3/8 hooks on the bucket free of charge.
   / Chain hooks? #8
Quite right about the paint. I've had to wrap a chain around my bucket to lift some stuff (I don't have chain hooks yet) and it doesn't just scratch the paint, it takes it off right down to bare metal.
   / Chain hooks? #9
Hi - Make sure that the dealer adds some support to the location that the hooks are going to be added... My dealer told of horror stories of people adding hooks with out additional support and bending the top lip of the bucket.
   / Chain hooks? #10
A second to what Bota Bound said. My dealer welded on a piece of steel on the top of the bucket for support, he also mentioned the bent bucket horror stories.
I hook a nylon strap around the 68? gallon garbage cans and then lift them into the truck, much easier on the back. But this way I may get carpel tunnel syndrome in my right hand.
Along with what most everyone else said.
steve
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
2012 JOHN DEERE 333D SKID STEER (A51242)
2012 JOHN DEERE...
2014 Chrysler Town and Country Van (A50324)
2014 Chrysler Town...
UNUSED FUTURE HYD HOSE BUNDLE (A51244)
UNUSED FUTURE HYD...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
Land Honor Skid Steer Pallet Forks (A50515)
Land Honor Skid...
