Chain Drive
   / Chain Drive #1
unclehan
Are there any tractors, harvestors, tillers, or any agricultural machinery that uses chain drive as one of its component?
   / Chain Drive #2
Chain drives are used on some tillers, many hay rollers, and several other attachments. A couple of older tractors were chain drive, but that is long past.
Ben
   / Chain Drive #3
My 1950 Case DC (and the SC and LA's) are chain drive from the differential shaft to the rear axle. It's (huge) 120 pitch chain and a not too difficult to replace. One for the left, one for the right. Case's logic at the time was the chain would distribute the load over many teeth where on a gear to gear drive only has two or three teeth taking all the load. I only had to replace one chain (on my 55 year old tractor) and that was due to a failure of the connector link.
   / Chain Drive #4
Case carried that design all the way through the 30 series Cases up to the 930 (80-90hp) and maybe the 1030 (100hp).
   / Chain Drive
It seems chains are a lot cheaper than shaft drives, so how come it's not widely used?
   / Chain Drive #6
Most tractors have the differential/final drive mated to the trans. so no drive shaft per say is used. Also as Case found out, 90-100hp is right at the limit for chain reliablity. The 70 series and everything after the 30's featured an all gear drivetrain to my knowledge.
   / Chain Drive #7
Motor Graders and Skid steer loaders use chain in their final drives… and all Track equipment use ‘chain’ as one of its components, the track itself is a large chain with pads attached /forums/images/graemlins/grin.gif. KennyV.
   / Chain Drive #8
</font><font color="blue" class="small">( It seems chains are a lot cheaper than shaft drives, so how come it's not widely used? )</font>
Also used because of the effecient transfer of power, but some would want you to believe they are bad, bad, bad, when used to drive a tiller. /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif
   / Chain Drive #9
Think tere is a chain somewhere in the transfer case of my truck. Its a little over 90 HP.
Egon /forums/images/graemlins/grin.gif
   / Chain Drive #10
Sears used to have their bottom basement lawn rider with an exposed chain drive.
Extremely Cheesy! And, a constant state frustration and melancholy for the user.
I had one, used it a year and sold it for $50.00 more than I paid for it. This was many moons ago. I doubt if they still use that drive system.
2025 SDLANCH SDLE18P UNUSED Mini Excavator (A53117)
2025 SDLANCH...
2010 Honda CR-V SUV (A51694)
2010 Honda CR-V...
2012 Ford F-350 Reading Service Truck (A51692)
2012 Ford F-350...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2025 CFG Industrial H15R (A50123)
2025 CFG...
Adams 6T Fertilizer Spreader (A53473)
Adams 6T...
