powerscol
Veteran Member
I have done a lot of searches here, but cant find all of what I need so far.
Its time for me to upgrade my chain and binders form the cam-lock to the ratchet style with the folding handle that I have seen. I know I need grade 70 or better (I have a mix now) and I believe I can use 5/16, ver 3/8 per this site Working Load Limits of Chain. I am hauling a Bobcat tractor 3600lbs and a Hesston 4550 baler - not sure the weight, but lets say 3000 lbs, Colorado DOT indicates I need 6 chains - 3 per side if hooked up to the baler, or 8 if unhooked (2 front and rear of each piece of equipment crossed on the deck if I understood correctly). Also I am getting a bit older, so weight is sometimes a factor hauling chain around for me, also arm strength which is whay I need to get new binders, and yes I have a cheater pipe for the cam lock ones, but got a nasty surprise the other day undoing one.
In reading up on posts I have questions.
Is it worth the money to go a higher grade of chain other than 70? I may have other uses such as towing or lifting with my loader.
Are all grade 70 chains equal as far as not rusting. What coating should I look for.
Are all grade 70 hooks created equal? I am finding various shapes and some with clips. Neighbor always uses clevises (C type with the screw in pin) to secure excess chain and as a safety measure. Good Idea or overkill?
Chain binders - what are good brands that have the folding handle. If I go with the 5/16 chain, can I use the binders sized for 3/8", or if I get the 5/6 size can I use 3/8 chain? I guess I could have replaceable hooks for the ends to change chain size.
I see lots of chain and binder sets, but they dont list the sources of all the parts. Would it be better (less expensive, better quality) to assemble my own with quality parts? I would only use 6 to 12 times a year.
Last - good sources for materials or sets that have fair prices. I know not to go to Harbor Freight for this. Local equipment dealers have them but pretty pricey.
Thanks for any help - :thumbsup:
