CH3510 Fel
/ CH3510 Fel #21
I finally got to see and test drive a CK3510SEHC.We also did a liader lift test 1600 lbs on a skid.
Was able to get it off the ground but was in desperate need of ballast. I am convinced it will handle my totes of wood.
Cab was roomy and did not obstruct my view as much as I feared.
Bottom line I was impressed and ordered one from my local dealer.
My wife and I are leaving on vacation Monday.
Tractor should be in by the time we get back in 2 weeks.
Two weeks of vacation, then a new tractor waiting when you return.
Doesn't get much better than that! :dance1:
/ CH3510 Fel
I know, you致e got to take your blessings when they come and appreciate them. Stop and enjoy the view from the mountain tops, because the next valley is waiting for you.
/ CH3510 Fel
Ck3510sehc delivered today.
So far so good.
I thought I read on here that there was a power outlet on these but I am not finding it.
Also looking for suggestions on after market stereos.
/ CH3510 Fel #24
So far so good.
If the OEM radio cutout and trim setup on the CK cab models is the same as on the NX, this unit will fit well.
Pyle - PLMR19W - Marine and Waterproof - Headunits - Stereo Receivers
You can find it online for around $45 and less. Amazon.com: Pyle Stereo Marine Headunit Receiver - 12v Single DIN Style Digital Boat In dash Radio System w/MP3 USB SD, AUX, RCA, AM FM Radio, Weatherband - Remote Control, Power Wiring Harness - PLMR19W (White): Car Electronics
Sound is quite good (and, hey, it's in a diesel tractor). Durable enough for marine use, and it's been working fine for me for four years. The NOAA weather band capability is a nice feature. Also lightweight, so no need to use a rear support strut. That would require raising the cab roof a few inches to get access from above. Not hard to do, if you want to bother and have a dry place to work. (You'll probably want to do that anyway, if you change out the front and back OEM work lights, or add side work lights).
BTW, the factory Kioti stereo wiring harness plug is reportedly compatible with this one Amazon.com: Stereo Wire Harness Isuzu Rodeo 2 3 4 24 (car radio wiring installation parts): Automotive as well as one available for certain Honda models. Or you can just cut off the Kioti factory plug and splice the wires. If you do that, leave about 3" of wire on the plug so you can splice it back in later if you want.
Also, this TBN link might be helpful https://www.tractorbynet.com/forums...379567-aftermarket-stereo-install-nx-cab.html
/ CH3510 Fel
Thank you for all the great information.
/ CH3510 Fel #26
So far so good.
Delivered yesterday, and still no pics for us?!?!? lol. Congrats, thats an awesome machine. I want one also but don't think I can afford or justify the cab model.
/ CH3510 Fel
I know I am a slacker.
Had company last night and I won稚 be home this evening so I hope for some seat time Friday evening.
So far I got to drive it around the yard and park it.
/ CH3510 Fel #28
As far as power outlet...I have a 4010sehc and there is one below my left arm as I sit in the seat. Hopefully that gives you an idea or rough picture of what I'm trying to describe. It's kinda hidden....
/ CH3510 Fel
Thank you, I found it right where you said it would be.
They hid that rascal pretty good.
/ CH3510 Fel #30
FYI, on my DK-40se/hst I use a Box Blade, BB and 2 55 Gallon plastic barrels filled with sand, at +/- 810#s/each. I strapped them in a leaning back position, and it provides close to or slightly more than my Kioti KB-2485 Backhoe. Your model may need less ballast, but this works well for me, and I can drop the BB and unstrap the barrels and lift each with the FEL as needed.
/ CH3510 Fel
Ok thank you
/ CH3510 Fel
OK so I finally got to play a bit this afternoon.
Then I remembered I was supposed to post a picture so here it is. It even got dirty today.
/ CH3510 Fel #33
Congrats. I just bought the same tractor, I'll have it next week. Adding to the NX5510HST, which I've had for 3 years and now has 750 trouble free hours. I wanted a cab for the 3 pt mist sprayer anyway. It big enough to handle everything but the 65" ditch bank mower and the 500 gal water trailer.
/ CH3510 Fel
Congrats to you too then.
May your days be filled with Opportunities and the wisdom to capitalize on them as they come
/ CH3510 Fel #35
Just delivered it today. Hooked the 72" rotary cutter up and off went my hand in A/C comfort. Handled the mower easily. Seems just as well built as the NX. Can't wait to spray with it, the shorter wheelbase will make it so much more nimble.
/ CH3510 Fel #36
Todd, very nice! I'm curious how the cab space in the CK compares to your NX. The NX is fairly roomy for a tall/large operator. I haven't been in a CK cab yet.
/ CH3510 Fel #37
I'm 6' 3" and it's roomy enough for me.
/ CH3510 Fel #38
Thanks. I'm impressed. That should be roomy enough for most operators!:thumbsup:
/ CH3510 Fel
I’ve had time to put a few hours on the new tractor and so far am quite happy.
I just split a few totes worth of wet red oak and the CK3510se he didn’t have any issues lifting and moving them around. I did use one tote full on the back for ballast.
I was able to stack the full totes as well. Something I hadn’t even considered before.
Now my firewood will take up less real estate.
Pretty sure I can stack em 3 high.
The air conditioned cab is just an added plus.
/ CH3510 Fel #40
That is awesome. How about some pics!
Exactly why I need (want?) to move up into a 3510 myself.
(2) BUNDLE OF MISC SIZE USED TIN UP TO 31' LONG (A62131)
(2) BUNDLE OF MISC...
16ft Cattle Panels (A64047)
16ft Cattle Panels...
UNUSED KJ 20' BI PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20' BI...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63118)
2020 Takeuchi...
Paladin 544K 416 IC 105in. Dual Cylinder Hydraulic Loader Attachment (A61567)
Paladin 544K 416...
2008 International 7300 Service Truck with Crane, VIN # 1HTWAAAN18J690230 (A61165)
2008 International...
