cfrednow
   / cfrednow #1
cfrednow
jax fl
l225 kabota
thak you for letting me in.
can someone help me find on my L225 kubota where to ajust the up and down on the hydralic.
it will not lift to high
   / cfrednow #2
:welcome: from Texas! Brianna will likely move your post to the location where it will get the most views, and therefore answers, from those with a Kubota.
I just wanted to say welcome to the group!
   / cfrednow #4
Welcome Fred
   / cfrednow #7
A photo of what you are lifting would help a lot. I doubt that you need to adjust the arms, most likely it is the top link that need to be shortened to allow higher lift. There isn't a lot of adjustment in the lift arms unless some one has removed them from the splined shaft and put them back on too low. How low do they go (how many inches off the ground is the ball joints when they are in lowest position?
New/Unused Self Dumping Hopper (A54865)
New/Unused Self...
UNUSED AGT TAS-50X PTO Driven Tiller (A47477)
UNUSED AGT TAS-50X...
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A55788)
2015 Ford F-250...
New Holland TN75S 4WD 75HP Loader Utility Tractor (A55787)
New Holland TN75S...
Kennco V-Plow (A53316)
