Hi - does anybody have any experience with a Cetme .308 rifle. I picked one up the other day (well used) and took it home to shoot. After loading the magazine and cycling the chargin bolt, it fired one shot, then failed to load the second shell. I cleared the jam, tried a different magazine (it came with 3 HK G3 surplus magazines), tried again, same result. I tried one more time, different magazine, different ammo, same result - except this time the shell did not eject and the next round in the magazine had the bullet (the actual projectile) jammed into the casing by 1/8 to 1/4" (keep in mind this is a .308 cartridge, so it was shoved in pretty good).
Anyway, I stopped trying to shoot and took it back to the shop where I got it the next day. The seller (very reputable - I was never worried about being stuck with a bad deal), said that the he had taken it on trade and it was very dirty. We called the former owner and he said that he had never had any problem. The seller then said that besides thoroughlyl cleaning it, all he had ever done was change a spring on the bolt assembly because when he got it, he had to put the butt of the rifle on the floor and bounce the gun on the floor in order to cycle the charging handle (he thought that was too much effort). Anyway, he replaced the spring, and now to load the rifle, you have to put the buttstock on the ground and give the charging handle a sharp hit to get it to slide. I took the gun back home and it fired through all three magazines flawlessly.
In conclusion, I like the rifle with the exception of the stiffness of the charging handle. Does anyone have any suggestions on a remedy for this? The seller has sold a few Cetme's before and didn't recall them being that hard to pull, but it has been a while. Any comments or suggestions would be greatlly appreciated.
Thanks and take care.
