Oil & Fuel Cetane Boost
   / Cetane Boost #1
joed3320
Hinesburg,VT
Johndeere
Thanks to all for the help with my tractor,I want to make sure every one Knows how I got great results with starting ,running and no black smoke any more.POWER SOURCE With CETAINE BOOST is the trick for your diesel.Thanks:)
   / Cetane Boost #2
I use it all year long. Never had the diesel gell YET in the winter with sub 0 temps... Cheap insurance.
   / Cetane Boost #3
Is "Power Source" the same as "Power Service" or is it a different product? Not familar with "Power Source".
Thanks, Ken
   / Cetane Boost #5
I have been using Amsoil Cetane boost and Amsoil Diesel concentrate for many years in all my diesel powered tractors and trucks. I have gotten very good results. hardly any black smoke and a smoother quieter running engine.
   / Cetane Boost #6
What you want is Power Service. I've used it in every diesel I've owned and never had issues. Just make sure you go White bottle not Red 911 bottle. While the red bottle is ok, it's for "oops" situations when you run straight diesel without winter mix and it gels on you..
It adds not only Cetane but also luberocity, which is important if you get a blend cut with K1, which has less parafins/lube.
   / Cetane Boost #7
There's a silver formula too. No anti-gel additive, so it's a bit less expensive. I use the silver jug spring/summer/fall, white jug winter. Fortunately, I've never had to buy the red jug.
//greg//
   / Cetane Boost #8
//greg//
Greg, good call there. I forget about that being up in the northeast.I usually have a stockpile of the white stuff and always forget they have a summer blend as well. If you have the option, I believe the summer formula actually boosts cetane more, but I could be wrong. Thanks for the addition.
   / Cetane Boost #9
Ditto good stuff:thumbsup:
   / Cetane Boost #10
Used to depend upon the mixing ratio. The labels then contained .32oz/gal and .64oz/gal instructions. But that's changed recently. Now the
white jug says .33oz/gal for cleaning + anti-get + cetane boost of 4 numbers,
silver jug says .33oz/gal for cleaning + cetane boost of 6 numbers.
//greg//
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2011 JACK  130BBL (A52472)
2011 JACK 130BBL...
HP DesignJet Z6 Pro Printer (A50325)
HP DesignJet Z6...
1267 (A50490)
1267 (A50490)
New Wolverine Skid Steer Hydraulic Breaker (A53002)
New Wolverine Skid...
