Cessna Pump - Repair or Replace
   / Cessna Pump - Repair or Replace #1
blake in spokane
Off of a harrow bed, pn#24500-510C Has broken 7/8 straight shaft, some wear on bronze plates, gears & center housing OK. Buy the time I mess with new bushings, seals/O rings, & the shaft or just get new. Who & Where?
   / Cessna Pump - Repair or Replace #2
Since Eaton Vickers bought Cessna years ago I am not sure if parts are still available for that model. Usually gear pumps are less expensive to replace vs repair especially if the side plates are scored. Motion Industries in the largest Eaton Vickers distributor in the US. Problem is finding a sales person that knows what you are talking about. Is there a Spencer Fluid Power office in your area? they used to be a Eaton distributor and may have some information for you.
I looked at my Eaton 900 CD and they do not show any model 24500 on the parts break down.
Roy
   / Cessna Pump - Repair or Replace #3
Blake,
New pump......last week, tried to find the same parts with no luck.......
even if you find them it'll cost what a new replacement pump will be..........
   / Cessna Pump - Repair or Replace #4
Maybe try Surplus Center .... A site sponsor. They have about 70 different Cessna pumps. None that seem to match the number you have posted but many that may work and certainly plenty with a 7/8" shaft size.
https://www.surpluscenter.com/sort.asp?search=cessna&catname=hydraulic&PAGELEN=10000
Steve
The gear diameter is 2-1/8 x 1-5/16 long. What GPM does that work out to?Thanks to all, As you can see I'm a newbe.
   / Cessna Pump - Repair or Replace #6
Does it have another number such as "24509 LBT"
if so then it's 2.40 CID............17.8 gpm's @ 1800 rpm @ 2000 psi
(.988 gpm per 100 rpm)
Reading from Cessna info
24503= 2.20 CID
24509= 2.40 CID
24504= 2.67 CID
24505= 3.12 CID
24506= 3.56 CID
Don't forget rpms when sizing/comparing other pumps
   / Cessna Pump - Repair or Replace #7
I am looking for a Cessna 62700-20c filter bank.please quote with shipping to Minnesota...
2012 Terex RL4 S/A Towable Light Tower (A53421)
2012 Terex RL4 S/A...
2012 TROXELL COMPANY 130BBL VACUUM TRAILER (A53843)
2012 TROXELL...
STORAGE FEES (A54607)
Polaris Side by Side (A50324)
Polaris Side by...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A55302)
2020 New Holland...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
