MicroPilot
Veteran Member
I've got some things I wanted to ask the Century owners if they have experienced.
1) While mowing some brush today I had my 3035 start free rolling. What I mean is that it felt like the tractor had shifted in to neutral or the clutch had been depressed. It rolled maybe 8 or 10 feet before it caught in gear again. A really scary feeling, as I was cutting down a grade!!! /forums/images/graemlins/shocked.gif This happened twice, and scared me enough that I got out of the field and took the tractor back to my garage, parked it, blocked the wheels and inspected the underside. I was expecting to see a stick or something jammed in a linkage, but didn't see anything like that. As a matter of fact I didn't see any linkage that I think brush could get jammed in to cause this kind of behavior. The only linkage that I saw that could have gotten jammed was for the brakes. Has anyone else had this happen? Any ideas on what might have gone wrong?
2) My reverse lights were not working as the tractor was delivered from my dealer. I noticed what looked like the light bulb laying loose in the housing, so I took it apart to stick the bulb back in. What I found was that the metal barrel that holds the light bulb had been puled out of the plastic base. It was like this on both sides. I pushed this barrel back into the plastic base and put the light bulbs in and they worked fine. However I noticed tonight that one of the reverse lights had quit working again. Probably came apart again. Anyone else had their rear lights come apart like this?
3) The bucket on my FEL was accting like it was in a "float" mode. IT was all floppy nad I could get it to bite into the ground. IT kept wanting to curl back up under the arms. I had to actually put pressure on it to keep it steady. This happened 2 or 3 times while trying to dig some rocks up.
I'll be calling my dealer about these issues tomorrow, but wanted to see if any of the TBN community had these problems also.
