Century Hydraulic leak
   / Century Hydraulic leak #1
anthonyk
houston texas
Century 3647
A month or so ago, I posted a question about what I thought was a PTO area hydraulic leak.
After much watching, cleaning etc, I believe that it's actually a small leak from the hydraulic fluid GAUGE!
That little glass with the level marks on it.
Has anyone every encountered anything like that out there??
Anthony
   / Century Hydraulic leak #2
Do you have a shop manual? Is the gauge flanged with a gasket or the typical round clear plastic gauge?
I don't have a shop manual, only the basic owners book.
I'll be checking with the Branson dealer up the road, they might know.
just thought that was odd.
anthony
   / Century Hydraulic leak #4
Anthony
Anthony, this is very common, and very easy to fix. Back the right rear tire up on some blocks, or use a jack, so that the hydraulic oil flows away from the sight glass. We have a concrete curb next to our loading dock that is perfect for this... Pop the site glass out carefully with a small screwdriver. Clean the sightglass rubber seal and the transmission housing with brakeparts cleaner or something like that. Re-install the glass with some RTV silicon. It will never leak again. About a 10 minute job, and you don't have to drain the fluid.
   / Century Hydraulic leak #5
Nice advice, thanks Dave.
   / Century Hydraulic leak #6
I had the same problem about 3 months ago on my 3510. Branson dealer said it was common with the old sightglass and sold me a new one (I think it was about $6). Pointed the front downhill, popped out the old sightglass with a small screwdriver, and popped the new one right in. No problem since.
Guys, I really appreciate those tips!
This site and the folks on it are great!
Anthony
   / Century Hydraulic leak #8
Hi folks,
I just wanted to add my two cents worth. My 2810 started leaking fluid from the sight glass around 100 hours. I called my dealer and ordered a new one. It was going to take several days to get due to the holidays. My dealer told me to silicone the old one. I cleaned and sealed the old one, with blue silicone sealer and it did not leak for about another 20 hours. I then put in the new one, which is a little different design and used permatex #85409 Ultra rubber gasket sealant & dressing on the new one. I have no leaks after another 20 hours and I hope it stays leak free. I will let you know if it leaks again. If it does leak, I have a redneck engineering plan for the next time.
Hey Dave at Daves Tractor, did I use the wrong silicone sealer??? Should I have used the black, red etc???
   / Century Hydraulic leak #9
jgreen said:
Hi folks,
The key seems to be cleaning both surfaces with brakes parts cleaner, or something similar. It needs to be real clean, not a bit oily. Then about any silicone seems to work. We've never had one leak twice.
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2019 Ram 5500 Dump Bed, VIN # 3C7WRNFL2KG599631 (A51572)
2019 Ram 5500 Dump...
2010 L3 MEP-806B GENERATOR (A52576)
2010 L3 MEP-806B...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
JOHN DEERE 9R640 LOT NUMBER 252 (A53084)
JOHN DEERE 9R640...
