Century C47 Rear Hydraulic Question
   / Century C47 Rear Hydraulic Question #1
Carmichaels
I have a Century C47 tractor and I have a question about the rear hydraulics and would appreciate any/all assistance or guidance that others may be able to provide.
I recently purchased a Befco 3 point hookup sickle bar mower. It has a hydraulic lift, which is really nice. However, once I set the bar to the desired height, it almost immediately starts to sag, and I need to keep readjusting the height while I'm mowing. I have checked the hydraulic fluid level on the tractor itself, all connections are tight and the cylinder is not leaking, but I'm still having this problem. Another farmer told me that the problem may lie in the tractor hydraulics.
Has anyone else had this problem, and if so, how did you correct it?
   / Century C47 Rear Hydraulic Question #2
I'm not sure if this will help or not but check the knob below your seat and turn it to "close". This allows the 3 pt hitch to drop at a variable rate and you can check this easily. Good luck and maybe some of the others will give better advice than I can.
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
2018 Nissan Sentra Sedan (A51694)
2018 Nissan Sentra...
2025 CFG Industrial H15R (A50123)
2025 CFG...
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
2023 JACTO JATAO-1000 LOT IDENTIFIER 262 (A53084)
2023 JACTO...
