Century C47 front wheel locked up
   / Century C47 front wheel locked up #1
jonbradley
Smithfield, wv
century c47l
Recently, while moving some dirt with my front end loader my right front wheel locked up. I tore the final drive apart and did not find anything obviously wrong. My 19th gear had a little wear on the inside of the teeth and so did my pinion gear on my axle, only less. I replaced both gears and their corresponding bearings. Today I put it all back together and it went about 20' and locked up again. Only, this time it will rotate in reverse. Anyone have any suggestions?
   / Century C47 front wheel locked up #2
Bearings? A gear that damaged would be obvious, I think. What a drag - it's testing you!
Jim
Starcraft Starlite 22ft Travel Trailer (A51694)
Starcraft Starlite...
2020 Bobcat T740 Compact Track Loader Skid Steer (A51691)
2020 Bobcat T740...
Land Pride RCF2072 (A50123)
Land Pride RCF2072...
Adams 5T HC Spreader (A53473)
Adams 5T HC...
Boat (A51694)
Boat (A51694)
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
