Century 3045 won't move forward or reverse
   / Century 3045 won't move forward or reverse #1
wildoakman
Pine Valley Ca.
Century 3045
The century 3045 quit moving when I was using it to move some dirt and debri up a hill. Then i was able to back up very slowly and then forward about 30 feet and it quit moving all together I tried adjusting the clutch that did not help could it be anything other than a bad clutch?
   / Century 3045 won't move forward or reverse #2
With that description it sounds like a clutch. Adjust for 7/8" freeplay and if it still slips, it sounds like it may be clutch time. The reverser linkage should be inspected, but by the way you have described this, it sounds like clutch.
The hydrolic fluid was 3 gallons low in the rear end would cause a problem other than the clutch as there are about 5 ways to put this unit in neutral?
Can the clutch be replaced by just pulling the engine?
   / Century 3045 won't move forward or reverse #4
Since it is a dry clutch, the low oil in the trasnmission/rear end would not affect it. You can pull the engine, but it is easier to leave it attached to the front frame rails and just roll both halves of the tractor apart.
2016 LOAD MAX 24 GOOSENECK (A52472)
2016 LOAD MAX 24...
2003 Honda 4x4 ATV (A50324)
2003 Honda 4x4 ATV...
KJ 20'x12' Livestock Metal Shed (A50121)
KJ 20'x12'...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
Bush Hog 3210 PT 10' Mower (A50121)
Bush Hog 3210 PT...
