NealinVA
While bush hogging a large field the PTO began to make a high pitched sound then went into a free wheeling mode (spindle was spinning but not driving the driveline shaft) I could not get the lever out of the 540 position for quite some time then I was able to move it all the way into the 1000 RPM position (after disconnecting the driveline shaft). After it sat for a day, I was able to move the lever to neutral but it will not move to 540 anymore. The spindle runs all the time now but is free wheeling you can stop it by grabbing it and holding it. It no longer makes any noise in fact the noise stopped when it first began to free wheel in the field.
I have read many posts in here and I am wondering if the clutch is gone.
This is a 2004 model with about 375 hours.
Any thoughts would be appreciated.
