Century 2028 Filter Crossreference
   / Century 2028 Filter Crossreference #1
CenturyGreg
Western Pennsylvania
Century 2028 C-50HL FEL
I am looking for an oil and transmission filter number to replace those on my Century 2028. I simply would like to be able to buy a filter without having to drive 40 miles to get it. I prefer a Fram or Purolator filter if anyone knows the numbers. Also, does anyone know if there is a problem with the warranty if filters other than Kukje are used? Thanks!
   / Century 2028 Filter Crossreference #2
Greg I bought a hydraulic filter from John Deer dealer b/c it was alot closer than my Branson dealer. The JD filter was the same size just a little shorter. I was told it wouldn't matter. Sorry but I don't have the # of it right now.
   / Century 2028 Filter Crossreference #3
The JD filter works, but we've had a few complaints in cold weather with the shorter filter. It seems the thicker oil has a hard time for a few minutes until it warms some, yet the longer filter, specifically the Baldwin BT372-10, works well. I hope this helps.
100GAL L SHAPED FUEL TANK (A50854)
100GAL L SHAPED...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A51039)
2018 Rock Solid...
MAGNUM PRODUCTS. 35KW GENERATOR (A50854)
MAGNUM PRODUCTS...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
Morooka MST 660VD Tracked Dump Truck (A51039)
Morooka MST 660VD...
