center link
   / center link #1
mark m
kubota l245dt
my L245DT came without top center link for 3 point, was wondering what length I should buy,
   / center link #2
Depends on your attachments. My OEM top link works for most of my attachments, but for the 3 pt finishing mower, I needed a longer one from tractor supply.
(I know...that didn't help!):confused2:
Deano
   / center link #3
As a starting point, I want the 3 pins on an attachment to line up in a vertical plane before I start making adjustments. Based on that, I'd want a top link that puts the top link pin in that position when it is in the middle of its adjustment range. That lets me tilt the implement forward or back and still have plenty of threads engaged.
It really depends on your particular hitch geometry, so I'd say go out to your tractor with a tape measure and approximate what length link would set your implement vertical, then make sure the link you buy lets you adjust a few inches longer than that.
   / center link
I would like to know what length is oem is , I'll go with that for now thanks
CABINET OF HOSE ENDS (A53843)
CABINET OF HOSE...
2007 Mack Granite CT713 Day Cab Truck Tractor (A53117)
2007 Mack Granite...
2011 John Deere 5075M 75HP 4WD Loader Utility Tractor (A52377)
2011 John Deere...
2011 GMC Savana 10FT Box Van (A51692)
2011 GMC Savana...
SHOP TOOLS (A53843)
SHOP TOOLS (A53843)
