Cement Mixer Repair - How to get at chain?
   / Cement Mixer Repair - How to get at chain? #1
sdboers
Bronze Member
Oxford Station, Ontario
Mahindra 4025 4wd
Hi - I picked up a practically brand new 3 point hitch cement mixer (Cosmo Mixer 80). Only issue is that the previous owner managed to skip the chain and get it stuck between the guard and the large sprocket. It looks like a pretty simple repair - but before I make it more complicated - I thought I'd ask... What is the easiest way to remove the drum (or the back guard) from the mixer to expose the sprocket?
Ok - figured it out. Had to press it out - but needed a bar across two strong points on the back to do it.
   / Cement Mixer Repair - How to get at chain? #3
I think I have the same problem, guessing the chain was too loose and it came off the large sprocket and got wedged. I thought I could unbolt the drum but that did not work since I can't get to the back side to loosen the nuts. Did you need to loosen the main bearing or does it just pry off?
43030 (A51691)
43030 (A51691)
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
2014 Ram 1500 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 Crew...
2022 Deere 333G (A50120)
2022 Deere 333G...
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A51572)
2007 International...
